d16z6 with pm6 ecm
Discussion in 'Civic and CRX - EF' started by Brojas, Jul 29, 2012.
  1. Brojas
    Brojas New Member
    marysville wa
    Hi I need help badly I have a 89 four door civic Lx. It has a d16z6 swap with a pm6 ecm.......I need help hooking up the vtec ive searched and searched how to do this with no success someone please please help!!
  2. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    I just sold the original PM6 ECU from my 1991 hatchback. It's an OBD0 non-VTEC ECU. You need something else. Probably something like a P28 - I'm not in the mood to research it for you right now as it's late - but, OBD1 with VTEC like a P28 - just use the search engine for D16Z6 ECU and it should find what you need. I just sold a P28 ECU too, that I used for a test unit when I did my swap.
    Good luck with it - you'll also have to do a bit of wiring and get an adapter harness for the OBD1 ECU. None of which is a big deal. Get the schematics for your car and schematics for whatever model the Z6 came out of. They can be found online for free - just download them.
    Fuck - now you've got me looking at 1:45am.
    The D16Z6 is a 1992-1995 engine which means it's OBD1 with native distributor. You'll need to change connectors at the distributor also. There are adapters for that too, but I would change the plugs on the car harness myself to make it clean.
    D16Z6 1590cc 125@6600 hp 106@5200 ft lbs 9.2:1 CR 75mm bore 90mm stroke SOHC VTEC OBD1 1992-1995 Civic EX/Si/Del Sol Si
    You're on the right path, now you have a thread. Some of the other guys will assist and I'll look at this tomorrow - the wiring schmatics I have may work for your car - I'll check them out.
    Have a look here at the wiring stuff for an idea of what you need to do - oh yeah, it will need a 4 wire O2 sensor too.
    http://hondaswap.com/auto-multi-media/zc-dohc-1991-hatchback-transplant-epilog-515235/
    If it has the stock OBD1 distributor in the D16Z6, it won't even run with the PM6 OBD0 ECU (even if you change the connectors and wire it up) as the angular sensors in the OBD1 distributor operate on ~40 pulses per revolution and the PM6 OBD0 ECU is setup for ~25 pulses per revolution.
  3. Brojas
    Brojas New Member
    marysville wa
    d16z6
    Thank you so much for responding!! So basically I still have to get the proper vtec ecu. And no way to do it with the pm6 ecu damn lol.
  4. Dual-500
    Fort Worth, Texas
    That is correct. With a distributor that is compatible with both the engine and PM6 ECU is would run, without VTEC. I don't know that there is such a distributor without modification to the mounting. Not something you would want to entertain doing as it wouldn't run worth a shit.
    Getting it wired up and working isn't that big a deal. What's important is that you get the correct schematics before attempting the work. Look at the link I posted for some basic wiring technique how-to's and what you will need in terms of parts for harness modification. Take your time and do the wiring right or you'll have problems upon problems.
    There's some talent and experience on this site - they'll be along shortly - be patient. For the mean time, you have enough now to get started accumulating the correct parts and related supplies.
    It will be worth the effort, assuming the engine is in decent condition. More power under the hood is a good thing. :)
  5. Brojas
    Brojas New Member
    marysville wa
    My civic runs and drives amazing it just don't have vtec hooked up and it's annoying
  6. Brojas
    Brojas New Member
    marysville wa
    And yes the motor is fully rebuilt
  7. Brojas
    Brojas New Member
    marysville wa
    I would love to exchange numbers maybe we can chat about my issue
  8. Dual-500
    Fort Worth, Texas
    Ok it runs, so it's an OBD0 distributor in it. In addition to the VTEC not working, the fuel/ignition timing tables will be off for that engine.
    Since it's driveable, and no worries about damaging the engine per se. You have time to do the research, obtain the correct parts and git r done.
    Changing to the correct ECU and wiring up the VTEC will be a huge wake up call for that engine.
  9. Dual-500
    Fort Worth, Texas
    I'll be happy to PM you my contact info and chat with you in time. You've got some homework to do first. :) Get the ECU & distributor, schematics + wiring components. By then, some of the other members will have responded to the thread. We can talk when you are ready to tear into it.
    Post us up some pictures too.
    No offense to be taken here, I want to see you are legit before I spend too much time with this.
  10. Brojas
    Brojas New Member
    marysville wa
    Will do that now
  11. Brojas
    Brojas New Member
    marysville wa
    Can someone please help me upload pics
  12. Briansol
    once you have 15 posts, you can use the attachment system.
    just make a few quick replies if you need to bump your post count.
  13. Brojas
    Brojas New Member
    marysville wa
  14. Brojas
    Brojas New Member
    marysville wa
  15. Brojas
    Brojas New Member
    marysville wa
    i followed steps on xenocron
  16. Brojas
    Brojas New Member
    marysville wa
    for 1 wire vtec
  17. Brojas
    Brojas New Member
    marysville wa
    with a/c relay
  18. Brojas
    Brojas New Member
    marysville wa
    and vtec still dont work
  19. Brojas
    Brojas New Member
    marysville wa
    anything im doing wrong?
  20. Brojas
    Brojas New Member
    marysville wa
    can i hook vtec to a toggle switch?
