D16z6
Discussion in 'General Tech and Maintenance' started by synergy2636, Mar 3, 2003.
  1. synergy2636
    synergy2636 Junior Member
    Having trouble with the motor making wierd noise between 4000 rpm and 5500 rpm. also motor sound like it is working too hard but is ingood condition. no smoke. maby oil pump going bad??? no check engine soon light. :(
  2. pissedoffsol
    what does it sound like?
  3. synergy2636
    It sounds like it is wineding up or building sometype of pressure and the vtec does not really seem to engage. like a gergaling wistle .
  4. blksun
    blksun Junior Member
    If you have an aftermarket intake that is most likely the cause. This is totally normally especially w/ a cold air.
