d18b vtec solenoid
Discussion in 'HYBRID -> ED-EF / DA' started by AHHVTEC, Oct 13, 2006.
  1. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i put a d15b vtec in my crx im running a p08 ecu the problem is that vtec wont cut on all the wires are were there supose to be the oil level is good, and ive jumped it to the hot post to see if it clicks and it does but im getting a vtec pressure switch code every few days it will go away then come back i put a new pressure switch on and still every few days same code ive reset it sevral times also and still no vtec even with no cades are on, any ideals
  2. ef8
    ef8 Junior Member
    You have converted to obd1 correct?
  3. AHHVTEC
    Alabama
    yup and ive tripple checked the wires to make sure ther correct, oh yea i also put it om a switch and i hit the switch at 5500 rpm and still did not notice anything but it clicks fine when i jump it to the hot post on the battery but only the pressure swith code is comming up every few days
