DA alternator
quickieinajiffy
will a b18 alternator bolt up to my b16? I've got a b16 with obd2 alternator from a '00 civic si in my DA integra and i'm sick of looking up how to splice obd2 plugs to my obd0 harness.. the other thing i was thinking about was just swapping out the voltage regulator.. does anyone know if you can do that? from a DA integra b18 alternator to a '00 civic si b16? thanks
So the alternator on the motor now is for a b16 that is obd2? And you want to change it to an alternator that is obd0? I am kind of confused why wouldnt you just use the same alternator that is on the motor now
my harness to the alternator is obd0.. three wires which i think is kind of weird.. i couldnt find any wiring diagrams that would make it possible to wire the three wire obd0 harness to the 4 wire obd2 alternator..
does anyone know about swapping voltage regulators?
