Death Is Coming
Discussion in 'Engine Building' started by white_hot_wagon, Apr 1, 2003.
Thread Status:
Not open for further replies.
  1. white_hot_wagon
    white_hot_wagon Member
    O-hi-o
    Don't mean to be a hater but if honda had thought it was a good idea to put a vtec head on that block don't you think they would have done it? that block can't handle high revs the way it is assembled because of R/S. it isn't worth it thats why Yeah maybe your hatch can run 12's with minimal effort but how long you think thats gonna last? if you knew your geometry you would know that there is a reason the ls and crv motors aren't capable of revving as high as a b16 or b18 and it's your R/S ratio. you take that thing past 7500 your gonna throw rods and totally f*&% up your cylinder walls eventually, your motor will not last if you use it on the street. that is the best it can be put. for drag use it's all right. and the whole idea is to make torque right? why the hell would you try to make huge torque with a small motor? (do i have to say it?)
    sure you'll make more torque but not a huge amount by any measurement. you're much better off with a b18 making high end power like you're supposed to with a honda or if you want torque, boost it. doing dumb stuff just gives a bad name to your brand. seriously guys........don't wanna be a hater, but think <_<
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    *ducks and covers, waiting for the napalming to begin*
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    :: patiently waits for calesta to come in here and rip him a new one ::
  4. white_hot_wagon
    O-hi-o
    oh with the composition on this site i know it's coming but you can't mess with fact my friends :ph34r: i'll take it from the bunker and become more hated than sadaam himself :lol: maybe i'm crazy eh? :spin:
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    when was the last time you built a b20/vtec and ran it on the street?
  6. E_SolSi
    looks like someone just read that BS article about B20VTECs and LSVTECs
    since when did Honda get into the business of producing full out race cars for the general public ?
    just because honda didnt do it doesnt mean it cant be done
    just because honda didnt do it doesnt mean its not a good idea
    if you take the time to build it corectly there is no problems at all with LSVTEC or B20VTEC setups
    if you do a hack job and throw it together carelessly then yes it will be a POS
    your arguement is not valid at all
    honda never put a turbo on a USDM car.... by your reasoning this would also be a bad idea cuz honda never did it and the engines werent intended to deal with the stresses of turbocharging ... shit by your reasoning its a bad idea to mod anything away from its stock form....
    :bash:
  7. B16
    yay area, CA
    and where are these facts you speak of? if you claim they are facts, you should back them up with resources or by explaining personal experience.
  8. white_hot_wagon
    O-hi-o
    i'm not saying tryin to vtec or otherwise mod a handa motor is bad in any respect
  9. phunky.buddha
    Dallas / Fort Worth, TX
    Not going to comment much...
    But this is basically taking ONE "bad" facet of the engine setup and using it to say the entire engine build is crap. The GSR engine has a R/S of 1.58 while the LS and B20 have a R/S of 1.54, and it works just fine up to 8000rpm and beyond. Domestic V8s have R/S ratios MUCH worse than 1.54 a lot of the time, and they spin up to 7000rpm and beyond all the time without any issues. There's a lot more to an engine than just R/S or "rod angle". Other things, like stronger rod bolts, crank girdles, beefier internals- it all matters.
    That's all I'm going to say- I don't have time to start a useless flame-fest... you all know my views, and you all know my credentials.
    End.
  10. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    Not only was that impossible to read, I find there is no point.
    the bottom end of the motor can be built to handle it - not a hard solution.
    "if you do a hack job it will come out like a POS"
    well fucking thank-you-sherlock. You solved the fucking case. You have given the solution to almost every single aspect of car building.
    kthnxbye
  11. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    well for a honda block to handle insane r/s ratios that v8s have, youll need a whole new block. many v8s and cars built for high low end torque have much stronger blocks, some made of iron.
    white_hot_wagon i see where youre coming from. but the excessive stress can be eliminated, or minimized, with simply stronger components. A good example is those small glow engines used in R/C cars. for their size they use relatively strong materials that are also found in automobiles. The glow engines can turn up to around 15,000rpm with no problems, or any damage, and they have a small r/s ratio(they ones ive seen are about 1.3).
    In some cases, stronger components wont help, and thats when youre revving it much higher than some 9000rpm. most street cars rarely spin that fast unless they are racing.
  12. white_hot_wagon
    O-hi-o
    well thank you ;) i'm glad someone is at least willing to see where i'm coming from
    i understand the better components and all that i'm just saing why not go with the engine that has a better ratio to begin with. i understand that the b18b is cheaper but to build it better it's gonna have the cost of the c anyways especialy if you're goin with the ls/vtec setup sorry for ruffling everyones featers
  13. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    The CRVTEC and LSVTEC are the two hardest swaps of the b series. You can do it two ways..
    1st way is the simple way, but the vtec head, slap it on there, do a little bit of wireing, drive away.
    2nd way and right way, rebuild the bottom end. New rods are the # one thing. Next, put it all together, spend a few hundred miles braking it in, bam, you have a very fast engine that is reliable (just dont rev to 9k when chasing a vette :) ) Only down side to the CRVtec is the cooling passages are not as good as the vtec counterparts making cooling a issue with extreme use.
    your hole argument is BS. That is like saying a b16 should never be reved to 9k. Yes in stock form, that high is pushing it but not many people keep them stock. With some better cams, retainers, valves and springs, 9k is no problem. Also with turbos, yes in a stock engine, put 20 psi in there, your going to brake something but with sleves, forged pistons, better rods, ect, the engine can do that.
    About ricers doing the easy way out. yes i agree but here, we do not prase everyone with altezzas and half assed cars. Go to superhonda and give this argument and everyone will belive you.
  14. Havok
    Havok Senior Member
    Florida
    Glad that someone mentioned building up the bottom end, which proves that white_hot_wagon is a fucktard. Thank you for stating the obvious, genius, we all know that the LS and CRV can't hold 8-9k like a C/CR, thats why they get new pistons/rods, block guards, girdles, bore it out, tune it, etc. Now shut up n00b. (Where's my emoticon, Mike?! :) )
  15. K2e2vin
    Raleigh, NC
    yo i dont think its right to call anyone a n00b on this forum. they could be a newbie here but a veteran on the street.
  16. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    thats what makes calling somone with a few posts a noob ok. if they are going to caome on here with 5 posts and tell eeryone who has built a motor that they don't know there shit then they deserve to be called a noob. cause as far as i'm concerned if you have 10,000 posts and you're going to tell someone who built their motor that they built the wrong one cause it had a b in its name instead of a c1 or a c5 then fuck them, they deserve to be called a noob.
    who cares if it isn't the perfect block, you can build it to become the perfect block. thats why its called building a motor.
    DUH!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
  17. brc80
    brc80 Senior Member
    Southern California
  18. sportlinecrx
    sportlinecrx Banned
    then what did u start this thread for? i suggest you think your opinions through further before starting any thread that makes a general statement. the guys who build engines already know that those swaps can be done right by reinforcing the block and what not.. and that it is possible to make reliable turbo setups. DON'T START THREADS JUST TO STIR UP FLAMES!
    :bash:
    thank you!
    drive through.
  19. Judo_boy_48
    Judo_boy_48 Senior Member
    I say this thread was a waste of time.
  20. hybridsol
    hybridsol Senior Member
    ohio
    if you are enough of a dumb ass to build a b20 vtec, and leave everything in it stock, then you deserve to have your motor junked, people that build b20/vtecs and shit build most aspects of the motor so that they can handle the high scale of stress that is put on the motor. just curious what do you run? a tempo? ok then, untill you build one yourself, don't knock it cause you obviously don't have any expierence. and don't come back with some bs like oh my friend built this and blah blah cause i don't want to hear it. flamer. please lock this topic and anyothers that come along like it, its all opinion and no one ever has fact to back it up. calesta props on your b20/vtec build what did that get like 40k???
Thread Status:
