New owner of a '94 Del Sol with JDM 92-95 H22A/tranny/ecu swap. It runs very good and I have no codes. The problem I can't figure out is: when driving and I let off the throttle and press in clutch/go to neutral the rpm's will sometimes stick at around 2k for 10 seconds or so then all of a sudden drop to almost stall (but never does) then searches for 10-15 seconds for idle then idles fine at 700 rpm's again. It doesn't do it all the time but often. I'd appreciate any ideas you have. I took off the IAC, Fast idle solenoid and throttle body to clean everything and tighten the fast idle white cap and made sure it worked with a lighter.
I'm leaning towards IAC being done. Let 'em rip......
