Depinning fuel injector clips
why not just cut/splice? it takes 2 seconds and the end result will be the same.
i know thats not what you wanted to hear, but i wouldn't even attempt it the way yoru doing it. too much work :)
Cut the wires, slide a piece of shrink tubing over both of the wires, splice the wires, shrinkwrap it. You won't be able to tell you spliced it.
Goddamn hippie. I meant smoke your injector clip. It's plastic, so you'd probably get high off of it.
Goddamn hippie. Buy a double kick pedal.
Hippie.
:p
some people... geez.
If you have a dremmel, get the carbide bit, and grind out the tabs inside the obd1 injectors, making it a square box. Then your harness will snap right in. Its alot easier than it sounds.
