Differences in Engine Bays
Discussion in 'General Tech and Maintenance' started by CRX-YEM, Nov 13, 2002.
  1. CRX-YEM
    Wallingford, CT
    B and I were talking the other day about motor swaps.
    91 CRX DX = D15B2 ( D series motor)
    94 Del Sol = D16Z6 (D series motor)
    A different D series can be put in each and bolts up no problem
    ie I can take a D16Z6 and drop in the Rex or I can get a D16A and drop it in either etc... without having to buy aftermarket motor mounts of fabrication
    know here's the kicker.
    Why can you drop a B Series in the Del Sol , no motor mounts need etc..
    but a CRX needs aftermarket motor mounts.
    What's different between the two. is it possible to use the motor mounts and frame mounts from a del sol in a crx and make it possible to just drop a b series in a rex ??
  2. SixtySecondAssassin
    Austin, TX
    are you saying that if a sol came with a d16z6, you could use those same mounts to drop in a b16?
  3. pissedoffsol
    we were talking- and i was like WTF.
    I have a d16z6 in my 5th gen
    Jeff swapped a d16z6 into his 4th gen, no mount kit.
    I am going to put the LS in- its known fact- no mount kit.
    So if b series works in 5th, and 5th gen dseries works in 4th, WHY doesnt b series work in 4th?
    its like a relational thing here...
  4. SixtySecondAssassin
    Austin, TX
    so i can use my stock mounts to put a b16 in my 5th gen?
    maybe they wont work because of the clearance on the sides. even after you get a b series mount kit for a 4th gen, dont you still have to bang on the inside of the wheel well?
  5. SolReaver
    SolReaver Senior Member
    i got it- the mount kit manufacturers knew they would fit with no mounts- but didnt tell anybody, its all a big conspiracy to get money for hasport. And until now, everybody automatically assumed that they wouldnt fit...bahahahaa
  6. pissedoffsol
    no... i dont think so. there must be some logic behind this...
  7. SolReaver
    if A=B and B=C then A=C
    its a conspiracy yo
  8. pissedoffsol
    but it makes no sense...
    i knwo 4th gen tranny mounts are different... but with a d-series in a4th, you use a 4th tranny due to it being cabel anyway....
    :confused:
  9. SolReaver
    only possibilites:
    1. Conspiracy ;) :D :ph34r:
    2. Your ls swap is not going into the sol
    3. A d15b7 is not going into the crx
    I dont know about you guys, but my vote is for the conspiracy :blink:
