Distributor Question
Discussion in 'ECU's, Electronics, and Tuning' started by fast4u1991civic, Jun 26, 2005.
  1. fast4u1991civic
    fast4u1991civic Junior Member
    Ok here is the deal I just completed a obd1 conversion on my friends 4th gen hatch and the car wont start and it barelly idles. I have done plenty of obd1 conversion on 4th gens and i have never had a problem. The only thing i did different this time is I used an obd0 SI Distributor. Are the OBD0 Distributers compatable with obd1 p28 ecu or do I have to get a OBD1/2 DIstributor to run with the p28. The motor is a D16y8 out of 1997 Honda civic. Please help ASAP the car i sitting and the track closes in 7 hours LOL.
  2. formby
    formby learning in progress
    go to rywire.com and buy the dizzzy conversion plugs.....so you can use the obd0 dizzy with the obd1 conversion
  3. ^crx^
    ^crx^ Senior Member
    but do you need to change any other sensors then o2?
  4. jdm2gen03
    jdm2gen03 Senior Member
    obd0 dizzy will not work with a newer ecu, sorry. have to run a dizzy that is either obd1 or newer to match with the ecu.
  5. ripperbone
    ripperbone angry bear
    Oklahoma
