DIY Broken Head Bolt Removal
Discussion in 'Civic and CRX - EF' started by Speed Box, Jul 7, 2007.
  1. Speed Box
    Speed Box New Member
    First, this thread is for people who have no money and a small problem with their block.
    Buy some ARP bolts and pay professional to do it if you have money, if you don't have money, keep reading.
    They break because dirt in the thread on the bolt thats it, you apply pressure and they go. Get a wire brush and clean the hell out of them.
    If you drill, use a small bit something like 5/16. Auto shop people told me use 1/4 and ez-out. Ok, except I broke 2 bits both 1/4 and after I use ez-out on that I need to re tap the block. If you HAVE to drill use small bits first and I recommend a Powerbuild brand kit for head bolt removal. It looks like a square looking thing ez-out it a twist looking thing. Ez-out have more chances of breaking then Powerbuilt.
    My method required NO drilling just 1 special tool. ( I broke 2 bits btw, one was a Dewalt.)
    Without this tool, you might have to drill, interesting if people found other methods.
    Special Tool ---------> For those that have seen the movie Total Recall, there is a part where Arnold takes this red ball out of his nose with this gadget. This tool is the same, it looks like a pen, really small and you press the button and 3 metal things come out to grab something.
    What you need to realize is ----> even that they broke, you can still turn them, to get them out. For me personally it was a hard concept to understand. One dude from a machine shop told me this. " as long as they are not rusted, you can turn them with a nail or something small and sharp, to get them out".
    Except those nails don't work neither do sharp objects.
    What you need
    1. Special tool ( I got mine from a computer repair type kit made by Fellows)
    2. 1 can of WD40
    3. Flat head screwdriver. long one. "99 cent store" one is perfect.
    4. Hammer
    5. Shop Rag
    6. Flashlight with some fresh batteries, (people might look at you funny when you trying to get bolts out under candlelight.)
    How its done
    1. Soak that hole with wd40
    2. Take your flat head and place it directly in the center of broken stud
    3. Smack it with a hammer few times, kinda lightly
    4. Stick your shop rag to absorb wd40
    5. Use your flash light to check inside the hole what exactly is there.
    6. Deep in there you should notice that broken bolt
    7. Use your special tool to grab it and turn it COUNTER CLOCKWISE, it will slip and slip and slip just have patience. Grab it, turn it, grab it turn it.
    8. If it don't turn, use your flat head and place it between bolt and wall of the block( yes you can do that) and smack it not too hard on the side of the screwdriver. Then repeat process.
    It takes alot of time and being sober helps while doing this.
    Its about 1-2 hours per bolt.
    :D
  2. matthewoleschuk
    matthewoleschuk New Member
    i have breoke many bolts and ez outs work great and i have never broken a bit and i have a cheap crill bit set and an ez out is like 6 dollars so if someone can afford that then they shouldnt be driving a car
  3. Speed Box
    I broke my bit while trying to keep it in the center and broken bolt was not exactly flat. It kept getting stuck against parts of the bolt that were not even with the part I was drilling.
    Its not that bits were bad or something, side of the bit grabs something and snaps. I have an ez out also, just never got around of using it. Its just a twisted piece of cast metal.
    Powerbuilt kit is just a metal spike something a bit more serious breaking wise.
    Althou I would have to agree that ez out is more user friendly I would guess, powerbuild kit you have to hammer it in.
    For some people 6 bucks is alot of money, less than 1hr of minimum wage sure.
    Got any clue how to get broken hood bolts out?
  4. 91DXHB2
    91DXHB2 New Member
    Dood
    Harbor Freight Tools - Quality Tools at the Lowest Prices
    find the one that fits the hole your bolt is in, slide it in and smack it.
    now you have a center on the broken stud.
    and you should start the hole at 1/16th or 5/64th not 5/16
    5/16 is not a small hole, you should never drill that big of a hole
    without a pilot hole first. no wonder you were breaking bits.
    next is use one of these they work wonders.
    Irwin Left Handed Drill Bits
    if that does not get it then its time for the easy out. the square shanked easy outs you talked about are about the best. imo they are way stronger than the twist in style.
    but hey if the claw of death worked then more power to ya.:thumbsup:
  5. Speed Box
    DxHatch you posted some important info. Thanks alot, it will help alot people.
    The reason I used bigger bits it was written on the ez-out. They measured my broken head stud and then check the chart and gave me 1 bit (1/4) and 1 ez out. I know WTF huh.
    If people decide to drill it out, some great contribution was made. Good call for sure.
  6. 91DXHB2
    91DXHB2 New Member
    yea no kidding, thats kinda retarded. but hey you worked around it and got it out and thats all that matters.:D
  7. Speed Box
    Its interesting to know other methods that people have done.
