Dizzy Help
Discussion in 'Civic and CRX - EF' started by 1sikef, Jul 23, 2008.
  1. 1sikef
    1sikef New Member
    Alright my brother has a d16y8 in his hatch and is about to convert to obd1 he has everything except dizzy i know you cant use a d16z6 dizzy b/c it wont bolt up but this is my ?
    Can you take the dizzy mounting bracket of a d16z6 and put it on the y8 head then run a z6 dizzy that way its just plug and play with the conversion instead of modifying the y8 dizzy and all that bullshit
    and one other thing ive heard you can use a d15b7 dizzy on a y8 head with the obd1 conversion is that tru?
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    just use the D15B7 distributor
  3. 1sikef
    1sikef New Member
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i thought it had to be a vtec dizzy for it to work
  5. james.macisaac
    james.macisaac New Member
    canada
    nah i took a d16Y7 and put a Y8 head on it. used all stock everything just had to get an 1998EX computer...my vtech works fine now. i didnt change distributers but i was told i needed the tech dizzy....but i tried it anyways and it works good. good pull for a sohc
  6. mintoxik
    mintoxik Member
    Oceanside
    ........not another one
  7. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Works on my mini...
