from the title, i would never have thought to look in that post either.. give him a break.
here's the real deal:
98% of cracked sleeves start from the bottom or middle, where the rod/stroke ratio is the worst- not at the top. they eventually crack towards the top, but thats not where it starts. with a block guard, you are holding in heat, and not really preventing any cracks from happeneing.
the best way to not crack a sleeve, is by tuning out ALL detonation.
The "overheating" problem from blockguards has nothing to do with the size of the cooling passages... it deals with the fact that the hottest part- the part where combustion occurs is at the very top of the stroke, right where the block guard lies on the outside. water can't pyhsically touch the sleeve there, because the guard is in the way. thus it gets even hotter, and leads to more detonation, and see above what i said about detonation.
Thats exactly the problem, it is going to keep a disproportionate amount of heat in the upper cylinder wall and base of the head around the cylinder. So if you're heating metal, its expanding right? And if you put different amounts of heat to a piece of metal, its going to have different coefficients of expansion right? Well, you're going to be putting more heat into a relatively small albeit important section of the cylinder wall as opposed to the rest of the wall which will be "cool" in comparison.
more info:
http://www.theoldone.com/archive/block-gua...odification.htm
IMO, sleeved, or stock.
