Do I have too high compression #s??
Discussion in 'Engine Building' started by 94CivicSlow, Jul 25, 2005.
  1. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Well I did a compression test again on my motor. I initially did one when the motor was brandy new and it was 180 psi across the 4. THe motor is built and has 12:1 compression ratio. After driving 1500 miles, I did my 2nd compression test and heres the results
    270 - 250 - 255 - 265
    Any comments.. I dont know what to think. The gauge only went to 300psi. The guy who I borrowed the gauge from said the numbers were too high, I think he was jealous cause he said my motor wouldnt last. He also noted the 20 psi difference between the 1st two was not a good thing. I think some rings are fully seated, or some kind of tollerances come into play.
    Feedback on this would be great.. THanks
    EDIT: iTs a ls vtec, b18b1 bottom with SIRII head.
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    sounds about right for the CR piston you are running and as long as each cylinder is within 10% of each other (which they seem to be) ou are golden...
    matt
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    numbers seem about right for a high compression motor....
  4. 97CTR
    97CTR Senior Member
    yep those are excellent numbers. They were low to begin with b/c your rings probably had fully seated yet.
  5. phunky.buddha
    Dallas / Fort Worth, TX
