Do I need to lower CR?
Discussion in 'Forced Induction' started by B16aJWHO, Apr 5, 2004.
  1. B16aJWHO
    B16aJWHO Junior Member
    I have a b16a2 with a t3 turbo kit on it. I am using a vafc w/450's for fuel. I currently still have the stock 10.4:1 compression. Do I need to lower the compression if I want to run 8-10 psi safely?
  2. pissedoffsol
    1000's of people have done it successfully
    1000's of folks have blown up.
    your choice- your risk
  3. turbo4dr
    turbo4dr Member
    TUNING! Enough Said! If you want to go fast for a month or two just drive it and worry. if you want it to run like it was ment to be turbo than get to a dyno with what you got or with hondata(the shit)
  4. jaydemdc2
    jaydemdc2 Member
    seattle wa
    Tunning is the key....
    i ran my b16 on 10psi and never had a problem with it, it may have been luck or not, who knows.
