does anybody know where the Baro sensor is?
CRXproject
:unsure: i have an 89 honda crx si 1.6, its giving me a code of 13 flashes wich indicates that the Barometric Pressure Sensor might be un hooked, or damaged. does anybody know where it is so i can check it?
Originally posted by red95solsi@Feb 4 2004, 06:34 PM
baro is inside the Ecu... sounds like you need a new ecu
that is on 1992 and up, on the ef, the sensor is on the right kick panel. it is actually called the atmospheric pressure switch. If you want to argue with me fine, but i am looking at the honda shop manual right now. the part number is 37836-PH7-003
