DOHC ZC head what block can i use??????
Discussion in 'HYBRID -> ED-EF / DA' started by zcrex1981, May 4, 2005.
  1. zcrex1981
    zcrex1981 Junior Member
    Ok i have a dohc zc head i was wondering since technically a zc is a d-series motor would i b able to use any or d-series block
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    no. You have to use the DOHC zc block too, because as far as I know, thats the only DOHC d-series block out there.
    you can almost NEVER put a DOHC head on an SOHC block, or visa versa.
  3. 88bluehf
    88bluehf Senior Member
    Denton,TX
  4. Dysturbed_90dx_4dr
    Dysturbed_90dx_4dr Junior Member
    The USDM D16A1 "Brown Top" was also a DOHC but you cannot as far as i know use the ZC head on the D16A1 USDM block. The bolts don't line up i don't think. Also the motor mounts are in a diffrent place on the integra than the civic if you are putting it in the civic.
    Dysturbed
  5. zcrex1981
    I am using a d15 block there is a thread that had a zc head with a d15b7 block so now i see that it is possible so i am goin to use that. With everyone's opinion i am not too sure if i want to do the swap what is ur opinion if i may ask???
  6. msonia03
    msonia03 New Member
    probly dead thread, but im a new member.
    i also have a dohc zc head that is nicely built and recently aquired from a friend. just wondering what block or blocks i can use with it.
  7. jlicrx
    jlicrx Senior Member
    Colorado Springs
    you should have started a new thread - but, 88 and up JDM DOHC ZC head will fit on the JDM DOHC ZC block, but will not work on the SOHC D-series block without a lot of special and time consuming machining - it will also fit on the 86-89 Integra D16A1 block, however, the D16A1 block will not bolt into the 88-91 CRX/Civic chassis without fabricating a custom driver's side engine mount - the D16A1 block also has a slightly different transmission attaching bolt pattern and has a different starter mounting
    essentially, for use in the 88-91 CRX/Civic, the JDM DOHC ZC head only works with the 88 and up JDM DOHC ZC block
