dohc zc with vtec... what should i be boosting?
Discussion in 'Engine Building' started by Rex-a-tronLovagurl333, Oct 12, 2007.
  1. Rex-a-tronLovagurl333
    Rex-a-tronLovagurl333 New Member
    i dont have the motor yet, but hopefully i will soon... also, im gonna do it no matter how hard it is but what exactly would i need to put vtec on a dohc zc? by tha way its gonna be in a 91 crx si...:D but its also gonna be turbo... what should i boost at since zc are high compression? i was thinking 4 but could i go higher????
    help!
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    there are no VTEC DOHC ZC engines and no way to make them VTEC - you can boost the stock DOHC ZC to 5-7 psi without any problems - you need to get the right fuel management for any boosted engine
  3. Rex-a-tronLovagurl333
    ive HEARD of ppl making zc's vtec but never acually seen one. if you can make a b20 vtec, why not a zc???
  4. cv14500
    cv14500 Banned
    you should boost it at 20 psi for sure it`s not like the engine is going to let go of it is new .
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    There are ZC VTECs; but not DOHC ZC VTECs. The ZC VTEC's are essentially D16Z6s and have different head bolt patterns than the DOHC ZC. The regular SOHC ZC non-VTEC is similar to a D16A6 and also has a different bolt pattern than the DOHC ZC.
  6. NickBeam
    NickBeam New Member
    Ky
    "for sure" if you run 20 lbs of boost on any stock honda engine it will blow up. Ever heard of floating cylinder walls? Why do you think all the guys running lots of boost have sleeved engines? Do some homework before you give someone advice.
  7. dtob
    dtob New Member
    I think he was being sarcastic.
    To the guy who started the thread. Have you tried doing any searching about this topic??
    You will spend more money trying to make your DOHC ZC vtec than its worth. Just buy yourself a z6 or something if you want to stay D series and want vtec. If not then keep the ZC and just boost it as is because you will spend too much getting the vtec and not get any hp out of it.
  8. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    because all B Series Motors are DOHC. The only D series VTEC motors are single cams so how would you go about putting it on a D series DOHC block? get it?...
  9. norcalgsr
    NorCal
    I tried explaining that to this person before they even posted this.. I think he/she must be retarded lol!
