door lock
Discussion in 'Body / Exterior / Interior / Cosmetics' started by skimboard71104, Sep 22, 2010.
  1. skimboard71104
    skimboard71104 New Member
    jersey
    When i bought my car it didnt lock from the inside on either door. i took the panel off and saw that there was a loose plastic piece on the rod and didnt know where that went? does anyone know where that is suppose to go? my other question is, is this the reason why my car wont lock from the inside or is it something else?
  2. haao13
    haao13 New Member
    PA
    are you trying to lock it from the inside with the door open? and is it the drivers door?
  3. skimboard71104
    jersey
    yea i mean i rarely lock my doors from the inside but on occasion i do and it is both the driver side and passenger side.
  4. haao13
    haao13 New Member
    PA
    the drivers wont lock from the inside with the door open with out pulling the handle on the outside or inside. i think its so you have to use the key so you dont lock it in the car
  5. skimboard71104
    jersey
    it wont lock with the door closed either
  6. haao13
    haao13 New Member
    PA
    check the rods again. the only plastic part that i remember being on them is the little plastic clip at the end to hold it in place. did this just start?
  7. skimboard71104
    jersey
    ive only had the car for a year but i think i have to check the whole lock system. i think they might of put new locks in and just completely fucked everything up with it idk its been a mess as soon as a get money to start restring the interior its somethin else i have to fix
  8. Nykole0408
    Nykole0408 New Member
    Hattiesburg, MS
    Does the door unlock from the outside? If it does, it's probably not broken I wouldn't think. If that plastic piece was the reason it isn't working right, I would think the doors wouldn't unlock either... I may be wrong... I do you know you have to hold either the inside or outside door handle open to lock the doors, as was previously stated. Do you have any pics of the plastic piece you are referring to?
