double check
Discussion in 'HYBRID -> EG-EK / DC' started by BIGMAN, Apr 5, 2004.
  1. BIGMAN
    BIGMAN Senior Member
    U.K
    just need to double check i dont need to add any other wires, the reason i ask is that my 0bd1 chassis to 0bd2 jdm conversion harness should be being delivered this week. so just wanted to know because of the harness im getting, is there any other wires other than the vtec wires that i will need :feedback:
  2. pissedoffsol
    you gotta be more specfic dude
  3. BIGMAN
    U.K
    ok, the cars a 95 civic DX (obd1) the engines 99 b18c out of a jdm itr which is obd2. i went with getting a conversion harness because i had the p73 ecu that came with the engine,(the engine also came with the engine harness). i added the vtec wires, knock wire...etc to my stock loom, but i was just wondering if there were any others need adding because im using a conversion harness
  4. kyleirwin
    kyleirwin Retired OG
    Vegas
    IAB wire(s) if you're using the stock gsr manifold. search it up y0.
  5. BIGMAN
    U.K
    iam using the stock mainfold, but i thought id have only have to mess around with the wires for the IAB if i wanted to use an obd 1 ecu and im going to be using obd2 :blink:
