yessssssssssssssssssssssssssssssssssssssssssssss
theres a bunch of bug fixes...
FIXED BUGS
1. [ACP] Editing skin settings can result in 414 HTTP Status code and redirect fails
2. [AJAX] Editing topic title and description does not add moderator log entry
3. [Upload] openbasedir restrictions cause the image_check in class_upload.php to fail - allows all files but images to upload
4. [Lang] Importing a language pack with ] character at the end of the text strips the final ] (i.e. lang_ucp.no_photo)
5. [Posting] If forum is set to read-only archive, Quick Edit still allows you to edit the post
6. [BBCODE] List tag inside of quote tag causes double line breaks
7. Edit time restriction setting not properly inherited when a user is a member of more than one group
8. [ACP] Extra html tag in non-default template group descriptions
9. [ACP] Deleting a member does not delete the pm text records (but does delete the pm topic records)
10. [ACP] Selecting template bits, changing skin group, selecting new template bits, and hitting 'Edit Selected' produces a javascript error; Editing multiple templates only pulls up one template
11. [Reg] Login name still asked for during registration even when converge method is set to email
12. [RSS] Double quotes used in the "Add link" field cause the form to become invalid upon editing
13. [BBCode] Text that has multiple tags not properly stripped of tags in the PM popup window
14. [JS] Add Selected Text as Quote button no longer works in FF 1.5
15. [Search] New post indicators/board being marked not being honored for Today's Active Topics link
16. [Search] Manual search->search in topics does not restrict search to just the topic, searches entire forum
17. If url returned in Quick Edit formulates an html entity, html entity displays (i.e. act=something§ion=.. turns § into the entity display)
18. Hardcoded text
19. [Upgrader] Bad query in sql_1.txt; Updated documentation slightly
20. [Skin] Poll question pushes off the screen if question is excessively long
21. [Skin] Cell shading in inbox rows innaccurate until you click on it twice
22. [Msg] Character set not specified in the html archived messages
23. [ACP] Portal latest discussions setting group not properly closed
24. [ACP] Rebuild tools run by ids, instead of record row count, so a site with mismatched ids or several deleted records has to run the tool longer than necessary
25. [AJAX] Editing topic title, description, and member name lookups not working with alternate character sets due to html entities
26. Invalid charset is set in txt_convert_charsets/ipsclass.php
27. [Upgrader] Email addresses not converted to lower case when updating from 1.x to 2.x
28. [Cal] View Current Month/Week links do not respect calendar selected; Changing language/skin reverts back to default calendar
29. [ACP] Unlimited attachment space displays as 0 bytes
30. [Mod] IP Tools in UserCP searching for posts do not return queued posts
31. [Cal] Events out of order in board stats if there is a recurring event; Recurring events do not have event date on mouseover
32. Upload limits not properly inherited if one of a member's groups has unlimited global space or per-post space
33. Language jump gives white screen when visiting UCP component pages
34. [Mod] Selected counts not properly set on the moderator buttons in forum/topic on first page load
35. [ACP] Skin/images import hardcoded to use "uploads" directory, instead of configured uploads directory
36. [Poral] Updated Gallery portal plugin files to latest copies
37. [Subs] Special characters in the gateway configuration forms can cause the form fields to become invalid
38. [Subs] Apostrophe in package name causes Paypal transaction to fail
39. [Reg] & in display name is rejected, though it is not listed as an invalid character
40. [API] Topics/posts does not instantiate email and pass to post class, causing an error in the forum tracker function
41. [API] Topics/posts does not instantiate email and pass to post class, causingan error in the forum tracker function
42. [Portal] Poll bar-graph images wrap across multiple lines
43. Permission mask check not working properly for forum tracker when users have their group permission masks overridden
44. [Portal] Attachments are not parsed into the portal if not added into the post
45. [Portal] Removed useless settings (settings had no affect on anything)
46. [Msg] If you use RTE and save a message, then go to edit it, the bbcode displays as tags instead of parsing into the RTE
47. [Skin] Topic title pushes buttons off to the right of the header bar if excessively long
48. [ACP] Deleting member topics/posts does not properly rebuild post count (doesn't take into account forums without post count incrementation, or qued status)
49. Not all forums displayed in announcement form if show forum jump list setting is enabled
50. [PM] Sorting by name actually sorts by ID instead of name
51. [Cal] Added day to the nav bar when viewing list of birthdays for a given day
52. [ACP] Group title missing in header bar when editing settings
53. [RSS] TTL set as seconds instead of minutes
54. Language Abstraction for Subscription Manager gateway payment buttons
55. [AJAX] Added ability to enter blank topic description
56. [ACP] Searching for member by email, email is case sensitive
57. [RTE] Wrap in Quote bbcode posts bbcode outside of post area
58. [BulkMail] Sent to count does not accurately reflect number of members email was sent to
59. [Skin] BBCode legend missing from template
60. [RTE] Enter in IE makes two line breaks instead of just one
61. [Stats] Who posted list groups by name instead of id, can show same member twice if using display names
62. [Skin] Postbox not properly left-aligned in Opera
63. [Skin] Email addresses limited to 50 or 64 characters in register and login pages
64. [Skin] Queries link is explitely set white in skin_global
65. [JS-STD] IE not positioning cursor into textarea properly when text is not selected
66. [ACP] Admins who do not have access to the 'Admin' tab can still see the index page
67. [ACP] Editing a member, the email is case-sensitive
68. Ignore user posts setting not honored in last 10 replies preview on post screen
69. [AJAX] Entering html into AJAX topic title editing will display the html itself, rather than the code, until page is refreshed
70. Enable Emoticons and Enable Sig checkboxes not remembered when editing a post
71. [ACP] Export skin with parent changes will override child wrapper with parent wrapper
72. [RSS] Full character support added with new convert_charset kernel file
73. [RSS] RSS always imports the number of articles you specify + 1
74. [RSS] RSS always imports the number of articles you specify
75. [RSS] RSS feeds will still import on create/edit even if not enabled
76. [RTE] No preceeding http:// for images and urls causes bad paths
77. [ACP] Search for members by name or display name is case-sensitive (depending upon mysql server configuration)
78. [BBCODE] Nested indent tags not properly parsed back when editing
79. [IE] Some attachments try to download as 'index.php' or get corrupted
80. Wording is misleading in topic reply notification emails if you request immediate email notification of topic replies
81. If posts require moderator approval, they do not get subscribed to the topic even if box is checked to do so
82. [Msg] Folder counts not properly updated when the Empty PM folders feature is used
83. [ACP] Some icons are not XHTML compliant img tags
84. [ACP] When members require admin approval, the latest member/member count stats are not updated
85. [Stats] Stats keep resetting until manually recounted
86. Improper group matching in profile pages for warn-protected groups
87. [BulkMail] IE downloads email instead of previewing inline in manage bulk mail
88. Requesting lost password more than once can cause validation issues as original request is not cleared from database
89. [Subs] ACP uses name instead of members_display_name
90. [Warn] Displaying name instead of display name
91. [Reg] Banned email address message not returned properly on registration submission
92. [Reg] If force login is enabled, XMLOUT can't authenticate on registration page (doesn't work properly)
93. [Mod] Display name not presented in title bar when editing a member
94. [Subs] Find transactions screen does not present packages in the drop down list
95. [ACP] Added coppa flag to manage validating screen, added flag to indicate email or admin validation pending
96. [ACP] Column ordering parameter not being set properly on validating members page
97. Search can produce extra (invalid) page link under right circumstances
98. [RSS] RSs import count not reset when multiple feeds importing, causes import to stop after it hits 100 articles collectively
99. Custom field setting for Admin/Supermod viewable only not functioning correctly
100. [ACP] Improper closing html tag
101. Edited-By now only returns for quick edit if group cannot remove it
102. [DBAL] allow_call_time_pass_reference Warning
103. Clicking Forum Led By legend causes error message
104. [ACP] Clicking a member group name causes error
