dpfi-mpfi mini me obdo-obd1
Discussion in 'ECU's, Electronics, and Tuning' started by efminibeast, May 22, 2015.
  1. efminibeast
    efminibeast New Member
    Alright I have everything from the z6 head to the evidence and jumper harness. My issue is I am doing the dpfi. To mpfi. But can not find any info on were to hook the injectors I do already have jumper harness the only thing I find is people converting there dpfi. Ecu to mpfi I need info asap please help that is a a dpfi thaout of my 89 school hatch I've already have a z6 03 civic wiring harness as Well so Yes all four injectors getting resistor box on Monday also need to k ow if I can cut the distributor plugs off the z6 harness and splice on to my b2 harness 20150521_134415.jpg 1432283527908.jpg 1432283575285.jpg 1432283613161.jpg
  2. hermanaid206
    hermanaid206 New Member
    I've never done it for D,
    But I've one two separate occasions going b series in EF hatch obd interior/dash harness/jumped to obd1 ecu with obd1 bay harness. Resistor ground control and depending on ecu you choose, maybe some re pinning for injectors and signal wires. But I have spliced to my old ones to utilize the rail and injectors. If possible get matching obd injectors and rail to the ecu/ bay harness u use. I've also done it with swapping to 3 bar plugs or tps ect.. Just be sure the component your swapping clip for match's the resistance or voltages as the computer your conecting to runs off.
  3. Briansol
