Dpfi To Mpfi
Discussion in 'HYBRID -> EG-EK / DC' started by esi42, Jan 20, 2003.
  1. esi42
    esi42 Member
    Hey guys,
    I have an 88 Civic LX with a 1.5 Im going to swap an CRX Si head onto my block. I have an intake manifold, TB, fuel rail, and injectors from an 88 integra with a d16a1.
    Can I use these to do the swap since I have them, or should I buy the actually SI parts?
    Thanks guys
  2. solblu
    solblu Senior Member
    Ricer
    If they fit they should work. Check the resistance 6-10 for low 10-13 for high you want low impedence injectors.
  3. Jeef
    Jeef NO MA'AM Moderator VIP
    The injectors should work, but I am not sure how the IM will fit on it.
  4. RFHOMI2U
    RFHOMI2U Senior Member
    any d-series manifold will bolt right on to any d-series motor. any d-series part is interchangeable. i'm not sure how you wire up the injectors or what you will need there, but i'm positive the manifold and fuel rail will work. from there, you'll just have to play it by ear and buy parts as you go. that's the best way to do it.
