rubber mallet, if you flare the end of the spline you won't get the nut back on. Thay ar esupposed to snap in. Not be beaten, sometimes the snap ring doesn't want to center itself. I use bearing grease and work it in underneath the ring into the groove. This will allow you to place it in the center, have it held by the thick grease, and have it snap in.
