Drive Shaft Help
Discussion in 'HYBRID -> EG-EK / DC' started by HondaMan_2002, May 14, 2003.
  1. HondaMan_2002
    HondaMan_2002 Member
    I can't get the drive shafts to go back in all the way. Does anyone know how to get them to go in all the way? Do I have to buy new set rings?
    Also want is the easiest way to get the shift pin back in?
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Turn your sterring wheel all the way,till you can easily motor the hub out of the way,then holding the outside part up and grabbing the inner joint give it is good solid shove,it should snap in.put as little pressure on the joints themselves as you can.
    "for the "bitch pin",you can use vise grip and close it all the way,but it gets awkward hammering it in like that.You can also get it started,then you a C clamp to tighten it in.It's a pain in the ass.I didn't even take mine of last time I pulled my motor.
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    get new pins dude.
