well tonight i installed some dsm 450cc injectors in a friends car. no leaks, but it idles rough, and once you hit 3500-4000rpms it stutters and loses almost all it's power. no matter if you give it half throttle or full. sounds like a freakin lawnmower.
what seems to be the problem? would a V-AFC fix the problem? cause i have one i can hook up tomorrow if some tuning will fix the problem.
more info on the car:
92 civic hb
LS/VTEC (gsr head/b18b1 block)
short ram intake
Skunk2 IM
DC 4-1
catback...
and SKUNK2 ecu
so what kind've settings should i set the vafc? or any other info would be appreciated.
Thank You,
Robbie
92 civic hb
short ram intake
Skunk2 IM
DC 4-1
catback...
and SKUNK2 ecu
Thank You,
Robbie
