dx ecu on b18c
Discussion in 'ECU's, Electronics, and Tuning' started by gsrjennie, Jul 21, 2005.
  1. gsrjennie
    gsrjennie Junior Member
    ok, first of all, my 97 hb is swap with an obd1 b18c using p28 upgraded ecu. i need to get my hb inspected (emission) inorder for me to get a tag sticker. i try the obd2 p72 ecu, but the CEL comes on. i was wondering if i run the stock obd2 dx ecu just for the inspection, will that harm or damage the engine? i haven't even try the dx ecu on the swap yet. don't know if it'll even crank up, but i know forsure, if it'll be weak if it dose start up. also, since i had to re-wire my harness to work with the obd1 b18c engine, will it throw any codes if i use the stock dx ecu? thanks.
  2. Pewble
    Pewble Senior Member
    whatever you do. DO NOT put the DX ECU on a GS-R. that just sounds like a HORRIBLE idea
