jpoenitsch
Member
Got the engine all in and wired up and she just won't fire. Did the old put the spark plug on the valve cover test and no spark. :unsure:
ECU throws code 8 TDC sensor, so I am going to go and look at that now.
If anyone has any other ideas or know what could throw off the TDC sensor please let me know.
Did the following:
swapped the 2 wires on the TPS
wired the 2 xtra dizzy wires to the ecu c1 and c2
wired the 2 injectors to the ecu a3 and a7
installed the injector resistor
pinned in the 2 wires cut off of c1 and c2 to b10 and b12
Did the following:
