dx to si gauge swap
dragon2003
how can i make an 89 crx si gauge cluster fit in my 89 civic dx?
What year did the cluster come from? Are you sure its from an 89?
88-89 Si had same wiring as 88-89 DX's
90-91 Si had same wiring as 90-91 DX's
i put a 89 crx HF gauge cluster in my 91 civic STD, becouse it had a tach. it bolted right up.
ALL THE WIRING IS THE SAME, THERE MIGHT BE EXTRA PLUGS FOR VARIOUS DEALER OPTIONS , BUT IT CHOULD PLUG AND BOLT RIGHT UP, I'VE DONE IT FOR A 88-91 HATCH, 92-95 HATCH.
Sorry bout the caps, i use it for work, so it always on, SO SORRRRY!!! j/k
anayways hows the cluster comming along
i'm just gonna buy a 89 civic si cluster from a local dealer, that way i know it will work, cause the crx si cluster won't work cause i tried to plug and play but when i turn the left blinker on the needle for the tach jumps instead of the indicator light blinking.
