eacv Question
69crx69
Member
What does a eavc valve do exactaly? I keep throwing the ecu code out for it, and i've tried two eavc valves to try to fix it and nothing. Would this cause an engine to run like crap?
Your EACV is an electrinic air control valve it allows air to pass by the throttle body to keep the engine idling with the throttle plate closed as for running bad it is possiable your would have a idle prob like it wont idle, rough idle etc
