EASY B series Transmission question
Discussion in 'General Tech and Maintenance' started by autox19, Mar 13, 2017.
  1. autox19
    autox19 Member
    Lansnig, Michigan
    I have a Y1 transmission. will the same driveshafts/mid shaft fit I swap to a later transmission (thinking hydraulic LSD)
    Odie
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    yes - axles and intermediate shaft will work - you will need to change the seal in the transmission on the driver's side for the intermediate shaft
    autox19 likes this.
