easyist way to swap a subframe????
Discussion in 'Civic and CRX - EF' started by 1991_civic_si, Nov 30, 2008.
  1. 1991_civic_si
    1991_civic_si New Member
    hey so i got the part for my car just wondering if n e of u know the easist way to swap the subframe fyi its the subframe that holds ur rack in pinion just asken so dont freak out on me i am sure i can do it but just wondering if theres a secret to it that will b helpfull well thank u
    p s if u know of n e sites that would give me a diagram that would help thanks
  2. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    unbolt the steering rack from the steeting column on the inside of the car at the firewall and undo the outer tie rods from the hubs. there is 4 i believe they are 15mm or 17mm not sure but there is 2 on each side that will drop the subframe with the rack i believe and then swap the rack over once its out. im sure it will be easier that way. i have had mine out a few times but that was before my motor was in but it shouldnt be much different
