ecm pinouts
arroshiz
i was just wondering, if the car u have is obd1 and the engine u are swapping is obd1 then the pinouts should still be the same on the ecu right? i've got a 92vx and im puttin in a b17a1 with the p61 ecu and i was just wonderin if the pinouts were the same as the p07 that came in the car
yes. basically, if the ecu does't have a feature (say, knock, or vtec) the pin is simply left blank/open
