ECU codes need help.
Discussion in 'Prelude' started by ihatemyprelude, Jul 19, 2008.
  1. ihatemyprelude
    ihatemyprelude New Member
    Ocala, FL
    Ok.. iam totaly new to the hole.. tuner stuff, just got a 92 prelude a week ago. and it is having a idle problme.. 700rpm - 1700rpm I got a new ( ICV) off my friend and it read 8-12ooms so thats not the problem. and i bleed the cooling system, that didnt work.. there are no vacume leaks. I was thinking the code for Map sensor could be the problme? just want to make sure befor i spend alot of money..
    and if any one can help me with the other 3 codes ( 9, 2, and 4 ) that would be great, thank you.
    3 MAP - manifold absolute pressure sensor
    9 CYP - cylinder sensor
    2 O2B - Oxygen sensor #2
    4 CKP - crank position sensor
    3- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 86-98 97-98 85-91 93-97 95-98 85-98
    MAP Sensor (Manifold Absolute Pressure)
    defective circuit or unplugged / defective sensor
    9*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98** 86-98 97-98 85-91 93-97 95-98 85-98
    CYP Sensor (Cylinder)
    * not a valid code for any throttle body injection Hondas
    ** not a valid code for V-6 engines
    2- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-89 86-87 n/a 85-87 85-91 n/a n/a
    Oxygen Sensor "B"
    4- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 88-98 97-98 88-91 93-97 95-98 85-98
    CKP Sensor (Crankshaft Position Sensor)
  2. ihatemyprelude
    Ocala, FL
    ok now, i reset my ECU by pulling the ( clock / radio fuse ) and now iam geting ( code 9 and 2 )
    i reset it and took it for a ride about 5 miles so that map sensor and crank sensor code would show up.
  3. BrutalB83
    Rochester Hills, MI
    What's so hard to understand about this? Just follow the codes. You probably need a new O2 sensor...
  4. ihatemyprelude
    Ocala, FL
    ya but would a O2 sensor, make my car rev from 700-1700 then back down when ever i idle?
  5. Ethan
    Ethan Well-Known Member
    Get a new o2 censor. There like 60 bucks! :D
  6. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    also with that number of codes, double check the wires. Could be someones hack job. Especially since you bought it that way.
  7. Ethan
  8. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    A bad TPS will.
