Ecu For B18a Vtec?
sooboss
ECU for at 93 Integra B18A With Vtec. Swap I am working on. Which makes my Integra a OB2 Right? What ECU Will work for this swap set up... which is my main question.. Will at 93 GSR ECU work for this..? Correct me if I am wrong. Also where can i get this ECU???
What car are you putting it into? You have listed nothing that is OBD II. The B18A is both OBD 0,from 90-91, and OBD I from 92-93. So you want to get the ECU that will fit your cars' ECU.
I am confused, did you build an LSVTEC? If not then you have a non existent engine.
if his car is a 93 its still a B18a but its OBD 1. All you have to do is swap the head, tap an oil line, run the VTEC wires, and get a OBD 1 VTEC ecu. and yeah, a 93 GS-R ecu would work.
