ecu for the dohc zc
Dark91zc
i went to the junk yard today and got a pr4 and a pg7. which one will better a better ecu and/or what ecu should i look for??? thanks for your help
[post=392825]Quoted post[/post]​
Yea i need to kno wat ecu to use also. Ill have my zc in this w/e. Ill use my dx ecu for a lil bit til someone tells me wat to get!
DX ecu probably will not work since it is made for dpfi setup. The pg7 (I think 89-91 version, could be wrong) ecu will work and has decent fuel curves for the dohc zc. Not sure on a pr4 ecu, do a search to find more info on it.
i know the pg7 is for a 88-89 integra and the pr4 is the b18a ecu 90-93 ecu.
i have been told i can use both but i need to know which would be better
