ecu from a B18a1 to use on a B20z swap
BodyDroppedNikes
...PENDEJO....
VIP
just outta curiousity, can the ecu from a B18a1 be used on a B20z? just wondering cause im going to get a B20z this winter and want to know if i am going to need the ecu or able to use the one for the B18a1. and im sure the fact my ecu is obd0 and the B20z is obd2 will have an effect on my answer....
yes thats what im runing my b20 on just bump up the fuel pressure a bit and use the obd 0 dizzy you will want to use the obd 0 injectors also or change the plugs takeout reistor box and use obd2 injectors.
