ecu issues
Discussion in 'ECU's, Electronics, and Tuning' started by Spoolin2g, Dec 3, 2008.
  1. Spoolin2g
    Spoolin2g New Member
    Hewitt, Tx
    Ok this has probly been asked a thousand times,but here it goes again. I have a 94 civic with a ls/vtec swap in it. its a b18a bottom, and a b16a head. it was running ruff one day and i took it to a shop, to check the cel, and the guy told me that i have the wrong ecu in the car, something about it still thinks it is a sohc motor and not a dohc. What ecu should i get or how can i solve this problem, thanks the noob
  2. DAallday
    DAallday New Member
    You should search this cause i'm sure it's been discussed alot. But for your car, i believe you can use a chipped p28 or an obd1 p72 ecu which came out the gsr. i'm sure there's more you can use but i'm to lazy to search it.
