Ecu Pinout With Pics.
Discussion in 'ECU's, Electronics, and Tuning' started by xj0hnx, Mar 6, 2003.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Some will find this useful.Though I am not sure about the ECU supporting a IAB from a GSR,since there isn't a OBD 0,GSR.hmmm.....any thoughts?
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    That is the best explanation for a pinout that I've seen. I just wish that you had one for H22A, but that gives a guy a way better idea. ;)
  3. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    H22 in a 4th gen is not a good idea.
    If you are putting this in a 5th or 6th gen, hit up www.hasport.com for more info.
  4. xxk0ssxx
    xxk0ssxx Junior Member
    thats the best guide i've seen does any one have a pinout like this for an 88 hb dx to a 91 crx si distributor? thanx
  5. crxswap
    crxswap Junior Member
    92b16vx where did you get this wonderful wiring diagram??
  6. xj0hnx
    C.C.TX.
    Katman on HT puts them out.And now there is another on there for OBD II.
  7. solblu
    solblu Senior Member
    Ricer
    You just add 2 wires.
    Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Sometimes there is a unused wire at B12.
    Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12
    Run wires from C1 and C2 on the ecu into the engine compartment. Label these wires for later use.
    Cylinder position sensor
    Connect C1 to blue/green wire on cylinder position sensor plug.
    Connect C2 to blue/yellow wire on cylinder position sensor plug
    the rest of the wires are color matched ur dx to the si wires
  8. papel
    papel Junior Member
    ok so lets assume that i am making my own conversion harness OBD-0 to OBD-1 for a P72 ECU......where would i run the VTEC wires to?
  9. OutOfSpecsCrx
    OutOfSpecsCrx Junior Member
    dear god it was so simple, so simple. oh the wasted years of picking my brain. thanx for the pix. they really make it simple.
    ozy :D
  10. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    damn man nice find....
    I wish i had seen this post all last week... :( it would have helped me out so much with my MPFI swap...
    oh well swap is done and runs right...
    But here is a good DPFI to MPFI swap chart:
