Ecu Problem
kakaroto_ss4
hey i have a problem when i accelerate my car its doesn't stand quick and is have a check light, when i hit the pedal the engine get low and do like it can't with the air in the chamber.
i have a ecu code= 4 short and 2 long. or 5 short and 2 long.
its a jdm d15b vtec with a p08 ecu :(:(:(:(:(:(
.... are you serious you cant differentiate between 4 and 5 short pauses? the way the ECU throws codes is long clicks first, then short, then a longer pause.
so short x4 would be code 4.
long x2 then short x5would be code 25.
2x long is code 20.
go look again, then come back and tell us the codes. and try to describe the problem better without relating the "feeling" of the car to non-automotive things... such as standing quick... or doing like it can't with air in the chamber (which i dont have the slightest idea as to what that means.)
Sorry i have a problem to read the light well i have a wired problem i have a big consume on my car but i found that the TPS sensor was disconnected from one cable. my issue is not longer exist but i have another check light so first i need to end whit the consume.
sorry I'm from Dominican Republic ya know bad English.
