ok, got my d16z6 with the IHI on it and i am going with uberdata i think
if you get uberdata you need no missing link or boost bleed off right?
the chipped ecu can read the boost via the map sensor with no CEL's right?
and i am under the impression you can use your stock fuel pump with bigger injectors, or a high pressure high flow fuel pump with stock injectors?
am i right?
setup = stock d16z6
p28
IHI off a 626
ford probe intercooler
240cc saturated
walbro HP 255lph
wideband o2 sensor...
you can run a wideband o2 for everyday driving right? and it will back feed a signal to the ecu while giving you a constant a/f ratio reading, right?
am i right?
setup = stock d16z6
p28
IHI off a 626
240cc saturated
walbro HP 255lph
