ecu type
Discussion in 'Civic and del Sol - EG and EK' started by chriscivicesi, Apr 25, 2008.
  1. chriscivicesi
    chriscivicesi v-tec lover
    n.ireland
    had a look through the tech stuff but still not sure what ecu is in my eg civic esi.has a d16z6 engine.think it might be the p28 obd1 but not sure because the tech section says the vtec comes in at 4500 on the p28 but mine comes in at 5000:confused:. thanks
  2. BrutalB83
    Rochester Hills, MI
    If it's a 92-95 Civic with a D16Z6 in it, then it's most likely a P28...
  3. chriscivicesi
    n.ireland
    does it say on the ecu anywhere just before i pull it out for no reason
  4. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Has your ECU been moded or chipped? My VTEC kicks in at 4,700rpm, which I thought was standard for Z6's. Either way, I wouldn't sweat it my friend. What's three hundred more rpm but more time that you spend in VTEC.
  5. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    pull the ecu out, it says on a white sticker on the side :)
  6. BrutalB83
    Rochester Hills, MI
    :werd:
    It should be listed on the sticker with the bar code; it will be part of a larger series of numbers...
  7. chriscivicesi
    n.ireland
    cheers appreciate the advise
  8. BrutalB83
    Rochester Hills, MI
    No problem man. Good luck with it...
