ECU? ZC wont start
Discussion in 'Civic and CRX - EW' started by CRXSi86, Sep 1, 2007.
  1. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    I just finished puutin a JDM Browntop ZC in my 86 CRX Si. Got everything hooked up correctly. went to start it and wont start. it cranks. fuel pump does turn on main relay works fine. i checked fuel pressure and im getting fuel up to the injectors.
    BUT...
    my injectors wont fire. im also getting spark and have comp. my PGM FI light doesnt do the system check and wont go on on my dash. I still have the stock Si ECU but heard it is possible to run on this. can someone please clarify that it does or doesnt. or give some other ideas what else it could be.
    If it helps. we did spray brake clean in the TB to make sure it wasnt anything else. it ran very well for about 5-8 sec. then died. so i know there is no fuel.
    Any help is really appreciated.
    Thanks
  2. hondaman321
    hondaman321 hondaman
    do u have the right injectors? u should be using injectors with a relay box
  3. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    yeh, i got itr running now, but its running extremely rich,well found out the dizzy is wrong as well as the IM and TB. just a suggestion to everyone, never buy a motor from hmotorsonline.com
    def. got screwed from them in many ways.
    its just about ready to go though
