Ecu
stud4u2c17
K when i get my swap with the ZC, i know how to do everything else but hookup the ECU, where is it at and how u hook it up?thanks
TJ
What car is this going into? On most Hondas, it is on the passenger side kick panel, on the right side. Just pull up the plastic rails (where people kick off sand/dirt/etc) and pull up the carpet. There is a cover and some bolts that you need to take off to get to the ECU, then just remove all the wiring and plug it in, assuming you don't need any additional wiring for the ZC.
on later models the ECU is located under the passenger seat, the harness is run inside a plastic square tube next to the door step.
