just finishing of swap in my ef b16a and using 90 teg axles now when ive read remove dust cap where abouts are they and how are they removed and why do you remove them?
i had a look at the teg we took axels out of last night its a 89 b16a teg did they change them in 90 to 93?
90-93 LS works for the Drivers. Depending on your half-shaft you'll need to make a "raxle" (86-89 axle with 90-93 inner joint) if it's the SIR. Or just a 90-93 LS if it's an LS midshaft. This site explains it all: http://web.archive.org/web/20010609105851/www.hasport.com/B16axles.htm
