racintweek
about a week ago i put my front LCA's w/ poly bushings in my 91 hatch
ever since then there has been a popping noise coming from where the LCA bolts to the subframe when i turn going under 5mph
i heard about not having the right sleeves in the bushings but i took them off the car and put the bolt thru and it looked to be correct
i put grease all over where the LCA bolts the the subframe and the noise went awayso i know thats the problem area , is this normal or are my control arms going to fall off
