Ef swap
BMS
Probably been said before, but I am very serious about a 88/89 civic EF with a B16/18. I need to know EXACTLY what needs to be done for this
yeah yeah yeah, i got lazy. don't worry, i've been around long enough to know the whole "stupid noob, use the search button" thing, but would it kill any of you to just give a goddamn post that ISN'T designed to make someone look like a retard?
If you so lazy as to not perform a search then how are you going to doa swap in your car? SEARCH MuthaFucka'... I hate Lazy n00b's
Here's the list:
A Brain,
modified mounts from Hasport or HCP,
Shift Linkages from Hasport or HCP,
You'll have to have your wire harness modified, to run MPFI, VTEC (for the B16)
(these are optional a new clutch, timing belt and water pump)
That about it...
