88HB4speed
Ok so im banging my head against a wall over this b serires swap i should have just left alone the running car, but i need to know why i cant use eg civiv ex hubs to do my b series swap so long as i use eg b series axles(will they fit a late model b series cable trans), is there something about the dimension or ball joint sizes on the eg hubs that makes them not usable on the ef.
2nd, the donr car, a ex civic with a b16 swap had nuespeed lowering springs, but when i set the shock/spring/and shockfork assembly next to one out of my crx( a stock hf) it is 2 inces taller(longer) can i use these eg assembly or are the shocks and springs to long and actually raise my car?
thanks for the help
thanks for the help
