ek h22a7
Discussion in 'HYBRID -> EG-EK / DC' started by fez, Feb 22, 2010.
  1. fez
    fez New Member
    hey guys i've got a h22a7 out or an Accord type R/Euro R and putting it in to a 97' ek(ej6) coupe i've bought mounts for it but the seem to push the engine to far to one side, i only have front and rear mounts on atm as the other 2 won't fit any help would be appreiciated
    thanks huw
  2. DESPAIN
    flower mound TX
    I thought the jdm/euro h22's only said h22a......... Could be wrong but......
  3. Matts96HB
    Matts96HB . Moderator VIP
    where'd you get the mounts from? Sounds like crappy design
  4. d-mon
    d-mon what r u compensating 4?
    x2, or for a different engine/chassis combination
  5. droszyk
    droszyk New Member
    Chesapeake, VA
    sounds like he is right. compare them to the mounts on hasport.com and i believe you can download the PDF file on how to install them too. all the bracket sizes and shapes should be the same as yours, if not then you dont have the right ones.
