I bought a damaged 96 civic hb cx and it was hit on the passenger door and quater pannel,so i need some parts and my buddy found me a smashed 2000 civic sir that was wreked in the back so i bought it and swaped the motor and the k-frame I used the entire harness and used the doors, which have power windows and locks.I hooked everything up I used the sir fuse pannel under the dash and under the hood.I put the drivers door on and turned the key and the window would not go up[they worked when we took them off] I cheked the fuses they were good and then I said fuck it i will try the other door ,may be they both had to be on for the windows to work ,still they will not work but now they are making nosies and so with the power locks,can anybuddy tell me what the fuck is going on?
