So I bought an EK with an H22 swap in it for a deal but the car was hurting pretty bad. The wiring in this car is a mess and I have no clue where to start with the problems. There was a shitty alarm system that spliced into every wire possible that I took out. I resoldered all of the splices but there are still a few problems:
When the driver side door is open and you press the brake, the left turn signal comes on solid and stays on and about a second later there is a loud beep, like when the ignition is in the on position. This stays on as long as the brake is pressed in. When the door is closed this still happens but without the beep.
Both reverse lights work except when the car is actually moving in reverse (when the brake isn't pressed in I'm guessing?)
On a separate note, VTEC is also not working. When it hits ~4800 rmps the tach starts jumping wildly. We tried switching the map and tps sensor but that didn't work, and we are thinking that it is a problem with my distributor.
Any help would be appreciated, thanks.
